Hi....
i'm still having problems with my d.mon....
After finally compiled the source file for Grassbeta3 I still get the
following message when I try to load d.mon start=x0
Graph_Set: can't open
Problem selecting x0. Will try once more
After scooping around in my RedHat6.0 system I found that the configure
file is checking for the curses.h file.
config.log : "checking curses.h WINDOW structure component..."
But then I recieve a error message telling me that my curses.h file does
not have the entry WINDOW (..or something like that)...
So I'm actually wondering if some of you, Grass-people, have a curses.h
file that runs on a RedHat6.0 that includes the WINDOW entry and that you
can send to me.... I would be very pleased, since this problem has
prevented me to use Grass since early Aug.
Sincerely Kjell-Olav Bjerknes
