d.mon X Error
Hello Grass people:
I have just upgraded my DECstation 5000/200 from ULTRIX4.2 to ULTRIX4.2a and
in the process I had to tar my grass system and then untar after the upgrade.
After the upgrade I can't get d.mon to start an X window. I don't think its
a problem with the ULTRIX upgrade but rather the tar and untar of the grass
software (permissions or something). I believe this to be the case because none
of my other X-window applications are acting differently, and d.mon had
permission problems from the start:
The problem lies probably with the named pipes fifo.1a etc., which tar can't
handle. You can use mknod to re-create them (I had the same problem when
I tried to run Grass from NFS and didn't realize that pipes had to be on the
local disk (silly me))
Martin
Martin Ameskamp, Kiel University, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.dbp.de
