is there anyway to change a setup that when i type in d.mon x3
the x3 window is in different size and location.
kee@harc.edu
WEI, TAI-FEN (t0w6975@summa.tamu.edu ) writes on 15 Oct 93:
kee@harc.edu
well, sorta (this question just came up recently).
The environment variables XDRIVER_HEIGHT and
XDRIVER_WIDTH control the size. If there's a certain
size that you always prefer, you can put these
in your ~/.grassrc file. Here's mine:
GISDBASE: /home/soils/h/mccauley/project/data
LOCATION_NAME: indiana
MAPSET: mccauley
PAINTER: ppm
DIGITIZER: none
XDRIVER_HEIGHT: 500
XDRIVER_WIDTH: 650
otherwise you can write a shell script to set the size
and then start the monitor.
Now, as far as location, I'm not too sure.
--Darrell
