Xlib: Client in not authorized to connect to server
Graph_Set: cant open :0.0
and the second batch is from the system ( i.e. OS) as follows:
X11/NeWS Network security violation
Rejected connection from: smokey.forestry.utoronto.ca (128.100.163.2)
For more information, see the xhost(1) and xauth(1) man pages
This is a common problem which occurs when you use grass (or
any other graphic program) in a remote machine... because the
remote machine attemps open a window in your local machine...
you must do "xhost +" in your local machine
and in the remote machine
"setenv DISPLAY (the e-address of your local machine):0.0"
in csh or
"export DISPLAY=(the e-adrress):0.0" in ksh
good lock
Nelson Segura
Concepcion
Chile.
