Hi! I'm running grass4.1 on DecStation 5000, Ultrix 4.3 with 24 meg
RAM. I have three maps, each covering a 110km x 140km area, with a
cell resolution of 10m. Each map only has one strip of 10km n/s by
the width of the map. Each strip is geographically seperate. The
three cell/ files are 1, 1.4 and 1.8 megs. When I use d.rast to
display these maps seperately, or overtop of each other (the -o
option) everything displays fine in a few seconds; HOWEVER, after
running r.patch to stick the three maps together, the resulting map
(about 4.2 megs) takes about 45 MINUTES to d.rast!!!
Anybody have any idea what's up? Did I just overshoot memory
requirements or something? The disk drive does not seem to pounding
away like it's swapping like crazy. I've even shutdown the system
and powered back up, but same results.
Professor Steven Rose, R.P.F. Phone: (705) 324-9144
Sir Sandford Fleming College FAX: (705) 878-9312
PO Box 8000, Lindsay, Internet: srose@flemingc.on.ca
Ontario, CANADA K9V 5E6
Sometimes when raster maps get very slow, I've done something
which expands the color table -- check out the map name
under your colr directory (under your database/location/mapset).
-Howard
Howard Foster (nsf@ced.berkeley.edu) Ph.D.
candidate^H^H^H^H^H^H^H^H^H, (got it!) Environmental
Planning, UC Berkeley. Phone: 510-848-1241
Here is something that works for me in cases of slow d.rast action:
slip in a color rule for what color category 0 (zero) should be (eg
use the r.colors command). It is a long story to describe what is going
on here, but it is a quirk that will be gone with the next grass
release.
Chris (rewerts@diego.cecer.army.mil) USACERL, Champaign, IL
release.
