Forwarded message:
From grass-lists-owner@max.cecer.army.mil Fri Jan 27 14:22:57 1995
Date: Fri, 27 Jan 1995 11:28:37 -0700 (MST)
From: DUNN JEREMY SIMON <dunnj@polarbear.colorado.edu>
Subject: d.vect floating point error
Sender: grass-lists-owner@max.cecer.army.mil
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Message-Id: <9501271828.AA11075@polarbear.colorado.edu>
X-Mailer: ELM [version 2.3 PL2]
Content-Transfer-Encoding: 7BIT
Precedence: Bulk
Good Morning,
I'm trying to run d.vect in Grass4.1 on an Alpha. OSF v1 1.3, 2.0 . I keep
running into a problem with a floating point error when trying to display
an example file "fields, roads, quads" etc in spearfish database.
Initializing [fields] ...Plotting .... Floating exeception (core dumped)
Has anyone experienced this problem before ? Is this a pointers problem ?
If so where a good placeto start to rectify the problem.
Running d.rast works fine.
Thanks
Jeremy
