There is a program under src.contrib/CAST [d.vect.cats] which
will draw user specified vector categories. This code
is a d.vect knock-off which could be further modified to
iterate through the vector categories drawing each in
a different color, or the program could simply be run
repeatedly in a shell script to achieve the desired result.
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
