d.what.vect
Hello GRASS-USERS,
I am using the g.region command non-interactively to create new
regions, I g.region region=new-region to set the new window.
This is working GREAT! I would also like to generate a report
of what is in that window, ie. category, area, sites, etc.
non-interactively.
The data I am working with is digitized Natural Resource Inventory
vector data of an area with a possible 3 sites in each area,
and I have no need to generated a raster file of this dataset.
I have used the interactive command of v.what.vect and that gives
me all the information that I need on the screen, I would like
to:
  goto the area label point (I can get the UTM from the
           dig_att file),
  find out what the GRASS category code is for the area,
  calculate the area in acres, and
        print this information to a file.
Has anyone any ideas of a non-interactive command resulting in
the same information of v.what.vect? Any suggestions on how to
write the shell to accomplish this task?
I am generating a table that I will pull information from to
generate the necessary support files to generate a postscript
output from mapgen.
Any assistance is greatly appreciated.
   Cynthia R. Brooks FAX (612) 290-3375
   USDA-SCS
   State GIS Specialist
   St. Paul, Minnesota email attmail!mn600g!mngis!crb
   Comm (612) 290-3645 internet mngis!crb@mn600g.attmail.com
