Is there any reason to drag along all of the lines in a dig_att file that
are associated with deleted lines? I have used v.clean to rid my dig file
of about 1000 lines, but the dig_att file is still the same length, with
lower case "l" replacing the upper case "L" for deleted lines (it appears).
Should v.clean also clean the att file?
Thanks
Brad Finney
Environmental Engineering, Humboldt State University, Arcata, CA 95521
I'm not sure (can't think of any reason), but you can do the following:
% egrep '(^A|^L|^P|^E)' $LOCATION/dig_att/file > /tmp/$$ ; mv /tmp/$$ \
if you definitely want to get rid of them.
--Darrell McCauley, Purdue University
