Default monitor size [Linux]
After resize the screen, you must always type "d.erase" (only with LINUX)!
NOT TRUE. You should always use d.erase after resizing the monitor in
X. GRASS does not know when the monitor has been resized therefore you
must tell it; using d.erase does this.
Ken Sibley
USDA-SCS "Hell, if you understand everything I say,
ksibley@ncg.scs.ag.gov you'd be me!" - Miles Davis
