Delivery status: Digitizer thru X-terminal???
A delivery problem was encountered with your message:
  Error 101: Unknown user at destination host
Recipient address(es) in error:
  ACHET.DCRP@mhs.unc.edu
---- Original text of message follows:
Question: Can a digitizer be made to function through an X-Window
display server runing on a PC ?
INFO: I am runing a Data General AViiON 4625 server with GRASS4.1beta
(soon to be 4.1) on an ethernet with two PCs runing MS windows 3.1 and
Control Data Vista-eXceed/W (for windows). The total setup works fine,
so far. Now, I want to connect a digitizer into the system but would
perfer to do so through the PCs network connection. Has anyone
donethis
before and have any info to support this function?
Thanks.
  Bill Miller
  DataProcessing Coordinator
  701-224-4288 FAX 3696
      bmiller@dg4600.swc.nodak.edu
--------End of Unsent Message
Bill M.
------------------------- Original message header:
From grass-lists-owner@max.cecer.army.mil Wed 26 May 1993 13:49
X-Envelope-To: ACHET.DCRP@mhs.unc.edu
Return-Path: <grass-lists-owner@max.cecer.army.mil>
Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Wed 26 May 1993 13:49
Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
id AA13829; Wed, 26 May 93 13:48:58 EDT
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA06356
(5.67a/IDA-1.5 for <ACHET.DCRP@mhs.unc.edu>); Wed, 26 May 1993 12:48:15 -0500
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA19410; Wed, 26 May 93 12:41:37 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA04753
(5.67a/IDA-1.4.4 for <grassu-people@amber>); Wed, 26 May 1993 12:41:36 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA19404; Wed, 26 May 93 12:41:35 CDT
Received: from dg4600.swc.NoDak.edu by max.cecer.army.mil with SMTP id AA06224
(5.67a/IDA-1.5 for <grassu-list@max.cecer.army.mil>); Wed, 26 May 1993 12:41:34 -0500
Received: by dg4600.swc.nodak.edu (5.4R2.01/200.1.1.4)
id AA06145; Wed, 26 May 1993 12:40:35 -0500
Date: Wed May 26 12:40 cdt 1993
Message-Id: <112670010243923EMU0000@dg4600.swc>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: Digitizer thru X-terminal???
------------------------- End of message header:
