A delivery problem was encountered with your message:
Error 101: Unknown user at destination host
Recipient address(es) in error:
ACHET.DCRP@mhs.unc.edu
---- Original text of message follows:
Hi, r.in.erdas does not seem to recognize the header as you have mentioned. The
workaround is to use r.support and edit the projection and region information
after you have imported the erdas coverage. Good luck.
Prasad
------------------------- Original message header:
From grass-lists-owner@max.cecer.army.mil Thu 27 May 1993 09:11
X-Envelope-To: ACHET.DCRP@mhs.unc.edu
Return-Path: <grass-lists-owner@max.cecer.army.mil>
Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 09:11
Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
id AA20520; Thu, 27 May 93 09:16:55 EDT
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA22241
(5.67a/IDA-1.5 for <ACHET.DCRP@mhs.unc.edu>); Thu, 27 May 1993 08:14:29 -0500
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26225; Thu, 27 May 93 08:05:51 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA14743
(5.67a/IDA-1.4.4 for <grassu-people@amber>); Thu, 27 May 1993 08:05:50 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26219; Thu, 27 May 93 08:05:47 CDT
Received: from landcover.inhs.uiuc.edu by max.cecer.army.mil with SMTP id AA22031
(5.67a/IDA-1.5 for <grassu-list@max.cecer.army.mil>); Thu, 27 May 1993 08:05:47 -0500
Received: by landcover.inhs.uiuc.edu id AA09647
(5.67a/IDA-1.4.4 for grassu-list@max.cecer.army.mil); Thu, 27 May 1993 08:05:40 -0500
Date: Thu, 27 May 1993 08:05:40 -0500
From: Anantha Prasad <prasad@landcover.inhs.uiuc.edu>
Message-Id: <199305271305.AA09647@landcover.inhs.uiuc.edu>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: Re: Please help:r.in.erdas problem
------------------------- End of message header:
