Delivery status: Re: Please help:r.in.erdas problem
A delivery problem was encountered with your message:
  Error 101: Unknown user at destination host
Recipient address(es) in error:
  ACHET.DCRP@mhs.unc.edu
---- Original text of message follows:
Be aware of the different headers for .lan files
created using ERDAS7.3 from those done with ERDAS7.4
higher. The lastest IMAGINE is using .img.
If you don't care the ERDAS colors, get rid of
the 1st 128B header and find a way to read
the rest. If your file is in BIL, it's not hard
to read them out and use maybe r.in.ascii somethinkg
like this.
--Xin Zhuang
zhuang@acess.digex.com
------------------------- Original message header:
From grass-lists-owner@max.cecer.army.mil Thu 27 May 1993 09:43
X-Envelope-To: ACHET.DCRP@mhs.unc.edu
Return-Path: <grass-lists-owner@max.cecer.army.mil>
Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 09:43
Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
id AA20865; Thu, 27 May 93 09:48:49 EDT
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA23234
(5.67a/IDA-1.5 for <ACHET.DCRP@mhs.unc.edu>); Thu, 27 May 1993 08:47:35 -0500
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26436; Thu, 27 May 93 08:37:59 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA15166
(5.67a/IDA-1.4.4 for <grassu-people@amber>); Thu, 27 May 1993 08:37:58 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26430; Thu, 27 May 93 08:37:56 CDT
Received: from access.digex.net by max.cecer.army.mil with SMTP id AA22854
(5.67a/IDA-1.5 for <grassu-list@max.cecer.army.mil>); Thu, 27 May 1993 08:37:56 -0500
Received: by access.digex.net id AA14580
(5.65c/IDA-1.4.4 for grassu-list@max.cecer.army.mil); Thu, 27 May 1993 09:37:55 -0400
Date: Thu, 27 May 1993 09:37:55 -0400
Message-Id: <199305271337.AA14580@access.digex.net>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: Re: Please help:r.in.erdas problem
------------------------- End of message header:
