I am still having problems reading in my dems. This is the output from the command m.dem.examine. Note the resolution (0)
MINDEGO HILL,CA BIG BASIN DEM DLG-DEM
min elevation: 224.000000 max elevation: 2816.000000
ns_res: 0.000000 ew_res: 0.000000
# of columns in file = 809773872file north UTM = 4136628.750000
file south UTM = 4122665.750000
file east UTM = 577600.937500
file west UTM = 566405.250000
-------------------------------Danimal
Have you tryed to use UNIX "dd" command to read DEMs from tape to disk
files ? If you have not, please try it with correct blocksize as specified on
the tape label. Then use "m.dem.extract" to read a DEM from the disk instead
of tape.
dd if=[tape_device] of=[new_filename] bs=value
m.dem.extract input=[new_filename] output=[new_rast_name]
blocksize=value
If you run GRASS4.0 on Sparc, this procedure should be working.
# # ## # # #### Wang Song (wang)
# # # # # # # # Center for Advanced Spatial Technologies
# ## # ###### # # # # ### 12 Ozark Hall
## ## # # # ## # # University of Arkansas
# # # # # # #### Fayetteville, AR 72701
INTERNET: wang@cast.uark.edu Tel: (501) 575-6159
FAX: (501) 575-3846
