DEM Extraction: How to?
In message <9706021714.AA20042@ouray.cudenver.edu> writes:
Dear Grass Users,
<snip>
Therefore, does anyone have a suggestion as to
where to look for a step by step procedure for extracting 1:250,000-Scale
Digital Elevation Model (DEM) data provided by USGS into GRASS 4.1 (if such
a document exist!) ?
I don't know where to find it, but here's my notes on how I do it:
To convert USGS dem files to GRASS format:
1. convert ascii file to binary:
m.dmaUSGSread top=1 bottom=1201 left=1 right=1201 output=binfname
        logfile=logfname < demfname
2. Rotate binary file 90 degrees, creating dem in lat-long format
m.rot90 [-q] input=binfname output=llfname rows=1201 cols=1201
     bpc=2
3. Convert from lat-long to UTM projection and put in GRASS database
r.in.ll [-s] input=llfname output=rastfname bpc=2
        corner=corner,lat,lon dimension=1201,1201
        res=3,3 spheroid=wgs72
    The latitude and longitude of the sw corner is the first pair of
the 6-digit values in the header of the original dem file. These six
digit values are arc-seconds. Divide by 3600 to get degrees. Enter
these values in the corner= input value for r.in.ll.
Hope this helps.
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
