I have been trying to use the m.dem.extract tool to
convert to grass 1-degree dem files available on the
net. (These are files -- not tape info.) However, I get
the error message described above. Is there an easy
fix?
(I realize that I could edit the (ASCII) dem files
with sed to remove header-type info, import these into
grass as raw ASCII raster files, then convert from a
radial projection to UTM, but this is looking like a
hassel.)
Any, any help would be appreciated.
-Howard
Howard Foster (nsf@ced.berkeley.edu) Ph.D.
candidate^H^H^H^H^H^H^H^H^H, (got it!) Environmental
Planning, UC Berkeley. Phone: 510-848-1241
In info.grass.user you write:
fix?
hassel.)
-Howard
Can you ftm the data to me please?
I modified the program to extract from disk file.
But I never got a hold of non-UTM DEM data to test it.
Thank You
Olga
