I imported a dem into GRASS using m.dem.extract. I now want to take this
file and export it into an image processing package (ENVI). To import the
file into ENVI, I need to know the number of columns, rows and the number
of bytes per cell. I looked in the header file and the dem has the
following dimensions:
rows: 1500
col: 1300
bytes: 4However, that doesn't agree with the file size of 921,574kb. I'm not sure
what is going on. Any ideas??Thanks,
Melissa Cowoski
Stanford University
cowoski@pangea.stanford.edu
The file is compressed by the standard GRASS compression, you must use
r.compress -u to uncompress it. It should then be the expected size.
Stefan J.
