Steve,
It seems to me that you need some criterion for delineating a catchment
boundary. For example, I did field work to determine the maximum distance
people seemed to be willing to travel from their village site to clear forest
for gardens or pasture. Then I used this value to define a circular-shaped
catchment area for each village in my study. You can use r.digit or s.buffer
to build a map which you can then use as a mask. Once a data layer is masked,
I have used r.report together with the r.le suite to generate land use/land
cover estimates, composition and other indices used by landscape ecologists.
Cliff Behrens
