DESQview PC.. problems with displaying raster maps!!
If you have the command xdpyinfo, run that and send the output from this
command to the list. The GRASS XDRIVER assumes that the Default Visual
is PsuedoColor, and I would like to see if that is true for you server.
xdpyinfo is a command I use to dump a lot of info about the X Server
and among this is info about all visuals you serve supports.
| We're trying to run GRASS on a PC running DESQview.
|The problems experienced with old xdriver:
| 1. Vector maps (even color) can be displayed without any problem.
|But
| 2. When we try to display a raster map, it gives a bunch of error
|messages like,
| X Error (major opcode 72 -- XPutImage). and the monitor dies!!
| When this problem was posted before there was a suggestion to go
|for the new XDRIVER.
|Problems with new XDRIVER:(for GRASS running on a PC through DESQview)
| 1. When we start the monitor (d.mon start) it self it says
| "Color: Can't set color 0"
| 2. When we try to display a color vector map it doesn't use the
|assigned color (infact no color can be displayed at all)
| 3. When we try to display a raster map the monitor dies saying
| "Segmentation fault"
|Appreciate all your help and suggestions,
|Laxmi P. Musunur (LP)
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
