different attributes in a raster map
Hi, grass users,
May be someone has a solution for my problem :
I have a base raster map ( 475 watersheds)
I have a cover raster map (dem)
I would like to get an output raster map giving, for each area of base map
(watershed),
the number of different category of cover map. (elevation)
I know that r.statistics is able to generate an output map including statistics
of cover map
for each area of base map. In fact, I would like to get a similar result for
the number
of different category values.
Thank's in advance.
Francois DELCLAUX
UMR HydroSciences Montpellier
BP 5045 34032 Montpellier Cedex FRANCE
http://www.mpl.ird.fr/hydrologie/mevhysa
mailto: delclaux@msem.univ-montp2.fr
Tel : (33) (0)4 67 14 90 11 Fax : (33) (0)4 67 14 47 74
Francois:
On Mon, 7 Aug 2000, Francois Delclaux wrote:
Hi, grass users,
(watershed),
of cover map
the number
These kinds of things have been done using the R/GRASS interface, using
the R statistics environment to apply a chosen function (here a frequency
count) to a vector (here the DEM) by a category variable (a factor in R's
terminology, here the watersheds). You can find some details on:
http://www.geog.uni-hannover.de/grass/statsgrasslist.html
and a later draft paper on:
ftp://reclus.nhh.no/pub/gc00/gc009_e.tar.gz,
including the latest interface package. A paper on the interface is
forthcoming: Bivand, R. S., (2000) Using the R statistical data analysis
language on GRASS 5.0 GIS database files. Computers and Geosciences,
26, pp. 1043-1052.
A practical question: how many cells are there in the DEM?
As an example, below the variable under analysis is the spearfish
elevation.dem at its original resolution, classified by the fields
layer. First they are imported, then the counts of the numbers of cells by
field are reported, and finally tapply() used to apply the
summary() function to the elevation.dem data classified by field (in your
case it would be the table() function, and classification by watershed):
GRASS:~ > R --vsize=20M
library(GRASS)
Running in /usr/local/grass-5.0b/data/spearfish/rsb
G <- gmeta()
summary(G)
Data from GRASS 5.0 LOCATION spearfish with 633 columns and 466 rows;
UTM, zone: 13
The west-east range is: 590010, 609000, and the south-north: 4914020,
4928000;
West-east cell sizes are 30 units, and south-north 30 units.
spear <- rast.get(G, c("elevation.dem", "fields"), c(F,T))
table(spear$fields)
                 no data C. Smith#1 C. Smith#2
                       0 756 700
             P. Biggam#1 P. Biggam#2 P. Biggam#4
                     350 3379 729
             P. Biggam#5 P. Biggam#6 P. Biggam#7
                     299 2906 621
         B. Cartwright#1 B. Cartwright#2 B. Cartwright#3
                    3123 328 312
Black Hills Natl. Forest
                  121379
tapply(spear$elevation.dem, spear$fields, summary)
$"no data"
NULL
$"C. Smith#1"
   Min. 1st Qu. Median Mean 3rd Qu. Max. NA's
   1162 1175 1179 1182 1185 1224 14
$"C. Smith#2"
   1135 1154 1161 1164 1172 1210
$"B. Cartwright#1"
   1199 1236 1260 1260 1282 1319
$"B. Cartwright#2"
   1195 1208 1214 1214 1220 1243
$"B. Cartwright#3"
   1193 1202 1207 1209 1216 1225
$"Black Hills Natl. Forest"
   1158 1408 1494 1505 1600 1840 23
(here using the summary() function rather than tabulation)
Hope this helps,
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
