I posted a variation of this question to the user group a while ago but thought
I might get more information here
We create an overlay with r.cross which is then converted to a vector using
r.poly. We perform some data-processing on the raster overlay, which we would
then like to incorporate into Arc/Info (basically, we modify the information
associated with each polygon in the map). Unfortunately, it seems that the vect
or
data (required by Arc/Info) has a different polygon count (about 50% more) than
the raster data.
My questions, in no particular order, are:
1) Why is it doing this ?
2) Can I avoid this behavior ? (ie. make them have the same # polygons)
I've been playing with this off and on, as I don't really have the time to go
source code digging (unless I have to 8-(
Thanks !
T.
Thomas Orth, M.Sc. Alberta Research Council
Research Officer 3rd Floor, 6815 8th Street N.E.
Advanced Computing & Engineering Calgary, Alberta T2E 7H7
Spatial Information Management and Analysis Canada
Email: Phone: Fax: WWW:
orth@arc.ab.ca (403) 297-7571 (403) 297-2339 http://www.arc.ab.ca
I'd be really surprised if my opinions reflected those of my employers.
