digitizer settings
I am trying to set up our Calcomp 9500 digitizer with the settings I received
from Ken Sibley. The digitizer I will be using is used being used by Arc-Info
users. I understand that it is possible to save a set of parameters, and that
the parameters used by arc-info are different than the ones for GRASS. The
problem I face is that the template was removed from the digitizer. How do I
"tell the digitizer" where the template is? It would be nice if I did not
override the Arc-info parameters in the process. Also how do I save the GRASS
settings to recall them when I start digitizing.
Thanks for any help. Kathy
Doyle
Kathy,
We use the following script to configure our Altek AC31 digitizer controller
for use with three different software packages (GRASS, Arc/Info, PCI). Perhaps
you can modify it to suit your requirements.
config_altek - written by Ravi Kiran, Center for Advanced Spatial Technologies
#!/bin/sh
#Program : To configure Altek Digitizer AC31
#confirm if this is the port being used for the digitiser
echo ""
echo " Digitizer Setup"
echo ""
echo " Program assumes serial port used is \"/dev/ttya\" "
echo -n " Is this correct ? (y/n) [y] "
read answer
#If default answer then serial port is ttya
if [ "$answer" = "" ] || [ "$answer" = y ]
then
  echo ""
  ser_port="/dev/ttya"
  echo " Serial port is $ser_port"
  echo ""
else
  echo ""
  ser_port="/dev/ttyb"
  echo ""
fi
echo " Enter the Application Number :"
echo ""
echo " 1. PCI"
echo " 2. Grass"
echo " 3. Arc-Info"
echo ""
echo -n " Enter Choice [2] "
read appnum
case $appnum in
  1) echo ""
     echo " PCI Mode selected for digitizer"
    echo \033 > $ser_port #Reset controller first
    #PCI setting
    echo R2 > $ser_port #Rate 2
    echo I5 > $ser_port #Increment 5
    echo P > $ser_port #Point Mode
    echo M1 > $ser_port #Resolution 1
    echo F1 > $ser_port #Format 1
    echo c1 > $ser_port #Carriage Return on
    echo l1 > $ser_port #Linefeed on
    echo B1 > $ser_port #Beeper turned on
    echo W > $ser_port #Save in NonVolatileRam
    echo ""
    echo " Initialising done for PCI"
    echo "" ;;
  2) echo ""
     echo " Grass Mode selected for digitizer"
    GRASS GIS Setting
    echo F8 > $ser_port #Format 8
    echo c0 > $ser_port #Carriage Return off
    echo ""
    echo " Initialising done for Grass"
    echo "" ;;
  3) echo ""
     echo " ARC-INFO Mode selected for digitizer"
    echo F10 > $ser_port #Format 10
    echo ""
    echo " Initialising done for ARC-INFO"
    echo "" ;;
  [4-9] ) echo " No Mode chosen !!"
    echo " Digitizer settings not changed"
    echo "" ;;
esac
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
