digitizer
Hi Grass users,
I am trying to set up our CALCOMP 9500 digitizer to our SUN station. The baud
rate is 9600 and the data bits are 8 bit. I looked at the list of available
digitizers in the etc/digitizer/ file. How can I tell if any of the digitizers
on the list correspond to the digitizer that we have? For example, what does
cc95f23_16 mean? Any help that you might be able to provide will be
appreciated. Thanks, Kathy Doyle
Hi, Kathy
If you look under $GISBASE/etc/digitizers, you'll see that the driver files are
ascii, and have a little bit of header info in each one:
124%>>more cc95f23_16
# Calcomp 9500 Binary format 23
# Originally build and tested by
# Terry Baker and David Gerdes USA-CERL 1992
setup
    digname = Calcomp
    description = Calcomp digitizer, binary format 23
    buttonoffset = 1
    buttonstart = 0
    buttons = 16
    baud = 9600
    units_per_inch = 1000
    stop_bits = 1
    data_bits = 8
    parity = none
(lines deleted)
Hopefully your digitizer manual should shed some light on what "binary format
23" really is!
Hope this helps,
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
