Digitizer
I am using GRASS4.1.5 on LINUX. My digitizer emulates Calcomp 9100
and I am trying to use it with v.digit. The digitizer seems to
be working okay when I run the calc_diag program. I can also
use my digitizer under MS-DOS. However, when I run it with
v.digit, I select my digitizer and vector file and the screen
prompt "Do you want to continue [y/n] ? " appears. when I answer
yes I get a segmentation fault. Can anybody give me some suggestions
to get my digitizer working.
Thanks in advance
Interesting timing. I finally got around to trying to figure out why
v.digit doesn't work with Linux, and I'm not entirely sure I figured
everything out -- in fact I'm entirely sure I haven't figured everything
out -- but I did get a version of v.digit compiled that works on my
44 Mhz 486, and also on a colleague's 200 Mhz Pentium.
The problems I dealt with had to do with Linux reads of the serial port
happening faster than the serial port was able to supply information, so
that often several error reads were returned for each correct read from
the serial port. There are various places in the v.digit code that didn't
handle these errror reads.
I'm pretty busy with a lot of things at the moment, but if any of you
have GRASS running on a Linux box, have a digitizer, and have found
that v.digit won't work with the digitizer, let me know, and you can
be some of my guinea pigs in trying to get this modified v.digit to
work.
If any other GRASS programmers have been working on this problem, let
me know, and we can compare notes and code, and see if we can come up
with proper, stable patches to v.digit that accommodate GRASS on Linux.
Tim.
Tim Martin * The worker earning $30,000
Spatial Information Systems * a year is subsidizing the
University of Alberta * salary of the $1 million
Tim.Martin@UAlberta.CA * CEO through her taxes.
(403) 492-6586 * - Alexa McDonough
work.
Hello,
I did compile v.digit2 on my Linux machine, but when I try in use my
digitizer, I can a message "Out of Sync with the Digitizer". Your
explanation that Linux reads of serial port happening faster that
serial port was able to supply information seems to be the problem.
Please let me know if I can get a copy of the v.digit version that
you have modified to work on your Linux machine.
Also, I am unable to compile v.digit on my Linux Machine since i
get a error message while running my gmake file. The error message
I get is;
"V_call.o(text+0xfs):undefined reference to '_waddbytes'
make...[/user2/grass/etc/bin/inter/v.digit] Error 1"
Please give me some suggestions and also let me know if I can have
a copy of your modified v.digit program.
Thanks in advance
ベンカテッシュ ラガワン Venkatesh Raghavan
大阪市立大学学術情報総合センター Media Center, Osaka City Univ.
3ー3ー138杉本住吉区大阪 558 3-3-138 Sugimoto Sumiyoshi-ku, Osaka
558
                  Tel:06-605-3381
mailto:raghavan@media.osaka-cu.ac.jp
work.
I have a SummaSketch II and need to digitize with it. I had tried GSMAP
8, but could not get it to work. I D/L GSMPA9 but have to wait on the
open file report to snail its way here from Denver.
I will be glad to try your program or any other. The SummaSketch is on
one machine (dos) and Linux is on another, but there are at least 2 ways
around this.
