Digitizer
v.digit binaries for Linux 2.0 (ELF) and GRASS 4.1.5
FTP site: brule.forsci.ualberta.ca
Directory: /pub/linuxgrass
Files: v.digit, v.digit.note, ccdbII6_16
The v.digit program in this directory is a GRASS 4.1.5 binary, compiled
for Intel Linux, on a computer running Linux 2.0, with the ELF libraries.
The "file" command returns the statement
   v.digit: ELF 32-bit LSB executable i386 (386 and up) Version 1
This v.digit works with a Calcomp digitizer in one of the ascii data
modes. I have a Calcomp DrawingBoard III digitizer, and select mode 6,
which is described in my manual as
   Calcomp 9100-3
I use the digitizer description file in this directory, called
   ccdbII6_16
I suspect I have corrected errors in the source to make this v.digit work
with any ascii digitizer format, provided the digitizer description file
is properly set up, and the digitizer binaries compiled. I leave those
details to you. I'm not sure I've fixed the source yet to work with
binary modes, but I might be able to get at that soon. Let me know if
they do or don't work with binary modes, if you get a chance to test this.
Installation
1. Put the v.digit file in your $GISBASE/etc/bin/main/inter directory.
2. Change the permissions and ownership to be the same as the other
   binaries in that directory.
3. If required, put the ccdbII6_16 file in your $GISBASE/etc/digitizers
   directory. Change the permissions and ownership as required. Add a
   correct description of this digitizer to your $GISBASE/etc/digcap
   file. See the GRASS installation guide for more information on
   defining and setting up your digitizer.
Tim Martin * The worker earning $30,000
Spatial Information Systems * a year is subsidizing the
University of Alberta * salary of the $1 million
Tim.Martin@UAlberta.CA * CEO through her taxes.
(403) 492-6586 * - Alexa McDonough
   Calcomp 9100-3
   ccdbII6_16
Tim Martin's version of v.digit works fine with my digitizer under its
Calcomp
emulation mode.I can (at last!!) use v.digit with GRASS4.1.5 on Linux
2.0.
Thanks
ベンカテッシュ ラガワン Venkatesh Raghavan
大阪市立大学学術情報総合センター Media Center, Osaka City Univ.
3ー3ー138杉本住吉区大阪 558 3-3-138 Sugimoto Sumiyoshi-ku, Osaka
558
                  Tel:06-605-3381
mailto:raghavan@media.osaka-cu.ac.jp
