hi,
I do like GRASS more and more, so no I decided to buy a digitizer.
Any hints which I can use under Grass? I'm especially looking for a
bigger size digi-board. (around 100x100 cm or 40x40 inch)
It must run under Linux/Grass.
Any hints is appreciated,
/Jonny
[Michel Wurtz]
| If you look at $GISBASE/etc/digitizer/, you will see that some
| digitizers are soon described. If you want to buy one that is
| not described, make sure that the vendor will give you enough
| documentation about the communication with their digitizer, and
| not only a brain-damaged Wintab driver !
Thanks for reply. I wonder if there is a list or if someone have tried
out other digitizers than $GISBASE/etc/digitizer/ (see list below)
I volunteer to collect information about working digitizers and
repost.
# Altek AC30 ASCII Format 3
# Altek AC30 ascii format 5.
# Altek AC30 binary format 8
# Altek AC40 digitizer, binary output format 8
# Calcomp 9500 ASCII format 12
# Calcomp 9500 Binary format 23
# Calcomp 9500 digitizer, Binary format 26
# Calcomp 9500 digitizer, Binary format 27
# Calcomp 9500 digitizer, Binary format 30
# Calcomp 9500 digitizer, ASCII format 4
# Calcomp 9500 digitizer, ascii format 5, uses keyboard input
# Calcomp 9500 digitizer, ASCII format 5
# Calcomp 9500 digitizer, ASCII format 6
# GTCO Super L Series
# GTCO Super L Series SL Mode 01 (Binary)
# Kurta Series 3 binary format 2
# Kurta Series 3 Ascii format 5
/Jonny
I'll be able to tell you in a few weeks. I have a Hitachi (which I got for
free) and I have all the docs from the company about the communications
protocol. It's a useful size ("D", or 36" x 48") and I am anxious to get it
up and running.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
