Digitizing Problems
I'm new to this list, and like many of you, I am currently banging my head up
against the wall trying to get GRASS up and running.
Today's problem is that I can't seem to get the digitizer to work (actually
it has never worked). It is an Altek AC31. When I use the v.digit2
or v.digit command, I get to the screen that asks me for the UTM coordinates.
I will fill in the UTM's, press Esc, and then get the following error
message: "Hold: Digitizer out of sync -- trying to recover." This message
repeats itself about 10 times and then craps out.
Is this happening because the digitizer that I'm trying to use is not
specifically listed among the menu choices, or is it something else that I'm
doing wrong? Any help would be greatly appreciated. Thanks.
Bill Green
wg1938@csc.albany.edu
