Hi!
I've just imported some *.e00 files
to grass through ARCINFO. I've made a
text document with the details of EVERY
step. Hope others wont lose as much time
as I have!
Agus
IMPORTING *.e00 to ARCINFO, CREATING THE FILES REQUIRED BY v.in.arc
AND RUNNING v.in.arc
alobo@ija.csic.es (July 1999)
1. Start arcinfo by typing
arcinfo
2. Import your e00 file:
Arc: IMPORT COVER vgeul2gg.e00 VGEUL2GG
3. Create the first ungenerate file:
Arc: UNGENERATE LINE VGEUL2GG vgeul2gg.lin
NOTE: you MUST use the LINE option regardless
you are exporting lines or polygons to grass.
v.in.arc will take care of this question
afterwards.
4. Create the second ungenerate file:
Arc: UNGENERATE POINT VGEUL2GG vgeul2gg.lab
5. Create the file with attributes:
5.1. Start info
Arc: info
INFO EXCHANGE CALL
08/07/1999 11:57:40
INFO 9.42 11/11/86 52.74.63*
Copyright (C) 1994 Doric Computer Systems International Ltd.
All rights reserved.
Proprietary to Doric Computer Systems International Ltd.
US Govt Agencies see usage restrictions in Help files (Help Restrictions)
ENTER USER NAME>
In my system I enter
arc
as USER NAME
ENTER USER NAME>arc
ENTER COMMAND >
5.2. Select the PAT info file created by IMPORT:
ENTER COMMAND >directory
TYPE NAME INTERNAL NAME NO. RECS LENGTH
EXTERNL
DF VGEUGG.TIC ARC0000DAT 71 12
XX
DF VGEUGG.BND ARC0001DAT 1 16
XX
DF VGEUGG.PAT ARC0002DAT 4160 20
XX
ENTER COMMAND >select VGEUGG.PAT
4160 RECORD(S) SELECTED
5.3. Define an ascii file as output:
ENTER COMMAND >output vgeugg.txt
5.4. "Print" the info file into the ascii file:
ENTER COMMAND >print
6. You should have files like:
%more /users/geodin/gloria/agusti/vgeugg.lin
more vgeugg.lin
1690
23.990833 71.037766
23.977499 71.039719
23.968330 71.043610
24.105831 71.048050
24.123053 71.045273
24.115000 71.041931
24.101665 71.039719
24.074997 71.037766
24.039164 71.039444
24.023888 71.037491
24.008053 71.037216
23.990833 71.037766
END
1693
24.768887 71.022217
24.737499 71.028046
24.848608 71.093307
24.853613 71.089981
24.846664 71.083588
24.843887 71.078873
24.847498 71.073868
END
etc
(the .../... just indicate deleted lines)
%more /users/geodin/gloria/agusti/vgeugg.lab
0 19.263294 58.363926
2 25.739523 70.986565
1 25.554712 69.857948
3 24.730162 71.050690
5 24.038237 71.049332
4 25.000187 71.021637
9 24.042933 70.944962
6 24.665106 70.992973
10 24.249376 70.856796
12 22.612419 70.582985
13 23.028830 70.836044
7 27.190071 70.783203
etc
%more /users/geodin/gloria/agusti/info/vgeugg.txt
1 -595.503 1,482.929 1 0 SEA
2 0.099 3.471 2 2 A1
3 11.829 63.930 3 1 A1
4 0.009 0.639 4 3 A1
5 0.005 0.665 5 5 A1
6 0.003 0.275 6 4 A1
7 0.021 1.494 7 9 A1
8 0.003 0.404 8 6 A1
9 0.001 0.182 9 10 A1
10 0.177 6.449 10 12 A1
etc
7. Quit info and arc by typing
ENTER COMMAND >quit sop
Arc: quit
Exiting ARC ...
8. Import to grass
8.1. Create a $LOCATION/arc directory and copy your 3 files there.
8.2. EDIT the txt file (vgeugg.txt in this example) and DELETE all
",". We call the new txt file vgeugg2.txt here.
8.3. Run v.in.arc
In my case, I used the 5th col as cat and the 6th as attribute:
v.in.arc type=polygon lines_in=vgeugg.line points_in=vgeugg.lab
text_in=vgeugg2.txt vector_out=vgeugg.v idcol=5 catcol=5 attcol=6
alobo@silvestre:~/grass/eurostat/vgeu/arc > v.in.arc type=polygon
Coverage type = polygon
The LABEL-TEXT file has been scanned. There are 4161
lines in the file and 6 columns in the file
Working...
v.in.arc finished.
Before vector file <delme> can be used in the 'v.digit' program:
Run the program v.support to build the needed support files.
alobo@silvestre:~/grass/eurostat/vgeu/dig_cats > v.support vgeugg.v
V.SUPPORT:
Selected information from vector header
Organization:
Map Name: vgeugg.v
Source Date:
Orig. Scale: 0
No snapping will be done
Reading Vector file.
100%
Building areas
Building islands
ls -l
d.mon s Attaching labels
tart=x0
d.vect Number of lines: 7712
Number of nodes: 5870
Number of areas: 4159
Number of isles: 2317
Number of atts : 4159
Number of unattached atts : 0
Snapped lines : 0
alobo@silvestre:~/grass/eurostat/vgeu/dig_cats > d.what.vect vgeugg.v
Buttons
Left: what's here
Right: quit
7:46:46.706587W 40:41:12.57485N
Line - Category <not tagged>
Area - Category 2837 S4
Size - Sq Meters: 54743224768.509 Hectares: 5474322.477
Acres: 13527016.909 Sq Miles: 21135.9639
7:29:44.91018W 38:24:58.203593N
Area - Category 3314 M4a
Size - Sq Meters: 80971672082.582 Hectares: 8097167.208
Acres: 20008049.983 Sq Miles: 31262.5781
****NOTE NEW PHONE NUMBER*****
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
