displaying maps from multiple grass locations
Dear GRASS users
This is probably a trivial question, but how do you display maps in a
location other than the one you're working in during a GRASS session?
(Apologies if this question has been posted before.)
For example, we have a location 'UK' covering the whole country, but we
also have locations for various regions within the country. Sometimes I'd
like to display one of the maps from a regional location whilst I'm running
GRASS in the UK location. The clumsy way of doing it is to export the map
using r.out.ascii from one location, then re-import it with r.in.ascii into
the other location, but this wastes both time and valuable disk space. Any
suggestions for better methods? Thanks in advance for your help.
Roy
Roy Sanderson
Centre for Land Use and Water Resources Research
Porter Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 222 7789
Fax: +44 191 222 6563
URL: http://www.cluwrr.ncl.ac.uk
On Thu, 20 Feb 1997, R.A.Sanderson wrote:
Dear GRASS users
Roy
Hi, Roy
Assuming that your different Locations actually use the same projection
and datum, simply make symbolic links of the mapsets you want to view
from Locations other than your current Location _to_ your current
Current Location and database is /data/grass/Location1.
You want to view mapsets A & B from /home/Roy/Location2.
ln -s /home/Roy/Location2/A /data/grass/Location1
ln -s /home/Roy/Location2/B /data/grass/Location1
Then, run g.mapsets.
Hope this helps you,
  -Malcolm
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
Roy Sanderson
Porter Building
Newcastle upon Tyne
NE1 7RU
United Kingdom
You could try symbolic linking the files together.
For instance, assuming the file is called coast@PERMANENT in location UK
and you want it in coast@here in location Skye, assuming your grass
database location is /data :
ln -s /data/UK/PERMANENT/cell/coast /data/Skye/here/cell/coast
repeat for cell, cellhd, colr, and whereever else coast is.
Good Luck.
Angus Carr.
Dear GRASS users
