Does any have any comments on this? I hasten to
report this as a bug (and waste someone's time
at OGI) if I am doing something silly, but
after having a few nights to sleep on it, I
still don't see anything wrong. --Darrell
There is a bug, but not in this code. The compiler ``thinks''
G_distance() returns an int because it is not declared in
gis.h as a double. (see fix below.)
-Raymond
I wrote on 31 Jul 93:
>I'm trying to do distance calculations. Here's a full sample
>program:
>#include <math.h>
>#include "gis.h"
>int main (argc, argv)
> char **argv;
> int argc;
> double x1=8.0,y1=7.0,x2=6.0,y2=5.0;
extern double G_distance(); /* <<<< should have been in gis.h */
> G_gisinit (argv[0]);
> printf ("projection: %d\n", G_begin_distance_calculations());
> printf ("G_distance: %g\n", G_distance (x1,y1,x2,y2));
> printf (" hypot: %g\n", hypot (x1-x2,y1-y2));
>Is there any thing wrong with this? I run this simple
>program under (x,y), LL, and utm, I get the same answers:
> GRASS 4.1 > simple
> projection: 0
> G_distance: 8
> hypot: 2.82843
>(that is, except for the projection). A distance of 8 is clearly
>wrong.
>I am linking the math library and $(GISLIB) when compiling.
>G_distance should just return factor*hypot (x1-x2,y1-y2), where
>G_begin_distance_calculations() initializes factor to be 1.0
>(for utm and x-y).
>What's going on here? %-|
