Hi people.
I started using GRASS 4.1 recently, and I think my problem is rather simple
and must have been solved yet . This is a reason why I am asking now for
some advices.My prob is :
Given a vect file and a point, I would like to generate a rast file where
each pix contains the minimal euclidian distance from this point to the set o
f
vectors defined by the vect file.Is there an already-existing function I could use ? In the other case,
which primitives should I consider ?
I suppose you can also rasterize the vectors, use r.buffer and
invert the result.
Ronald Wiemer
R.O.B. / Archis
Kerkstraat 1
NL 3811 CV Amersfoort
The Netherlands
Tel: ++ 31 33 4634233
Fax: ++ 31 33 4653235
