dlg's, standard/optional format
Eric,
Thanks for your reply to my inquiry. Since no one replied that a solution
exists for importing dlg3 standard format files into grass I have
developed a routine that converts dlg3 standard ascii files to dlg3
optional ascii files. So far I've imported a number of USGS dlg3 standard
format files with good success using v.import after converting with my
program. If any one else needs this capability, let me know and I will
ftp the compressed c source code to grass/incoming at CERL. All you
need to use the program is a c compiler.
Sincerely,
Jim Stafford
NRCS, Ohio
> Last year (Oct.14, 1994) Paul Loechl wrote to this list:
> "Has anyone developed a way to successfully import DLG Standard format
> files into Grass? the Grass tool v.in.dlg works for optional format files
> but not standard format."
> There were either no replies, or I missed them. Has anyone provided a
> solution to date?
> Thanks in advance.
> Jim Stafford
> Ohio NRCS
Can't answer the question, but if someone wants to write one, a good
description of standard, optional, and graphical DLG (I think DLG-3)
formats can be found in the document
ftp://spectrum.xerox.com/ds9/map/dlg/1:2,000,000/usa/doc/dlgguide.txt.Z.
Eric
Hi, Jim
Your dlg converter sounds like a really useful utility - my vote is for
you to place it on the moon. Thanks,
        -Malcolm
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Thu, 7 Dec 1995, Jim Stafford wrote:
Eric,
Sincerely,
Jim Stafford
NRCS, Ohio
s
> > solution to date?
> > Thanks in advance.
> > Jim Stafford
> > Ohio NRCS
> Eric
