I have a DXF file (geologic map) which doesn't import on Grass.
v.in.dxf runs Ok, says 100% done, quit gracefully and...
no file, nada, niet, rien :-((((
I tested the same DXF for import on other GIS (GeoConcept) or
tools (Surfer) and it worked.
This DXF was created with Mapinfo. Any similar experience ?
Is v.in.dxf bugged ? (v.in.dxf3d doesn't give any file, too)
Any helpfull advive will be greatly appreciated !
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
Michel,
MapInfo generates .dxf files using different AutoCAD versions. So, a lot
depends on what version of MI was used and which .dxf format was generated.
The range is from AutoCAD 10 through AutoCAD 13.
What I don't know is if GRASS is expecting a particular flavor of .dxf
file. That may be the problem.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc.
2404 SW 22nd Street
Troutdale, OR 97060-1247 U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax)
rshepard@appl-ecosys.com
Michel,
When you run v.in.dxf, the first thing it does is converts it to a
dig_ascii file. Your file from v.in.dxf is in the dig_ascci directory.
Then you will run v.in.ascii. This sould get you file in
good luck
Johnny Duke
Gis Tech
USDA/NRCS
USA
