dxf to polygons
I need to import some DXF files to GRASS.
With linear themes, the v.in.dxf3d does an excellent job; with
polygon themes I have problems in reconstructing the proper polygons via
v.digit.
I can first of all "re-type" arcs from line to area; however,
when I pass to assigning labels, the process succeeds only if the
polygon is composed by 1 or 2 arcs (otherwise v.digit says it
is not able to define a polygon).
At any rate, reconstructing the polygons manually can become very
time consuming.
I have re-checked the documentation on v.in.dxf and v.cadlabel,
and I see that there is no mentioning of polygon themes...
So: is it possible to reconstruct automatically a polygon from a DXF polyline ?
Maybe with polylines defining the arcs and text labels positioned
inside the polygons ?
I will be grateful for any hints !
                Andrea Giacomelli
                Centre for Advanced Studies, Research and
                Development in Sardinia
                Environment Division
                http://www.crs4.it/~andreag
I'm trying to import a raster file in ascii/text format with lat/long
coordinates into GRASS. The file has the following format:
north: 47.937500000000
south: 24.062500000000
east: -66.479166666667
west: -90.520833333333
rows: 573
cols: 577
785 790 786 783 779 771 768 766 ...
Hi Thomas-
rows: 573
cols: 577
I do not know, if it is possible to do the conversion with awk, but what
you might do, is to write a small program, that writes your data to
your sites directory and then do the import with an interpolation... :wink:
Have a look at the following part of my script, which runs at the GRASS-
prompt, doing this "task":
cd $HOME/grass_data/$LOCATION/$MAPSET/site_lists/
YOURPROGRAM YOURFILE >! $NAME
s.surf.idw input=$NAME output=$NAME
g.remove sites=$NAME
where YOURPROGRAM should do a conversation from YOURFILE to a file that
has the format
lon|lat|val
Do not forget the "|"!!!
(In my example YOURPROGRAM writes to stdout)
  Stephan
P.S.: It might be not very nice, but it works ...
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch@uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
Stephan,
Thanks so much for your help! I'll certainly give your suggestion a try.
Cheers!
Tom
Stephan Eickschen wrote:
Hi Thomas-
> rows: 573
> cols: 577
has the format
lon|lat|val
        Stephan
Corrensstrasse 24
48149 Muenster
Germany
Tom Adams adams@ohrfc.noaa.gov
                                       http://www.nws.noaa.gov/er/iln
Development & Operations Hydrologist NWS-Ohio River Forecast Center
1901 S. State Route 134 Wilmington, OH 45177
(937) 383-0527 (VOICE) (937) 383-0033 (FAX)
