Elevation data
I've got vectorial data representing isolines of territorial elevation
and would like to generate an elevation map as is required for 3d
display. There is no bounding rectangle, so r.surf.* fail. Is there
another way to do this?
No real problem, I think. Digitize the area you want to have interpolated
in v.digit (basically, an outline of the isolines) and convert this to
a raster map that you use as a MASK during interpolation - if I recall
right, the area outside the MASK will not be interpolated.
Good luck,
Philip Verhagen
                     philip@raap2.ivambv.uva.nl
                              R A A P
                        Plantage Muidergracht 14
                          1018 TV Amsterdam
                           The Netherlands
                        tel: +31 (20) 421 62 00
                        fax: +31 (20) 421 42 90
                http://raap2.ivambv.uva.nl/home_eng.html
