%%%> I am undergoing similiar 'driver' troubles with another
%%%> model ( Encad NovaJet, "E" inkjet) anyway...
%%%> I believe you will find that NewsPrint is Sun's proprietary
%%%> "postscript" stuff you're Sun-sales person should know
%%%> how to provide it... and provide info as to its applicability.
%%%> good luck,
%%%> Arlin
%%%> Arlin B Collins Info Sys Mgr - TIAER
%%%> arlin@tiaer.tarleton.edu Box T-258, 201 St. Felix
%%%> 817/968-9573 Tarleton State Univ.
%%%> fax 968-9568 Stephenville, TX 76402
%%%Arlin,
%%%We do not have the Encad Novajet plotter, but some of our state offices
%%%do. The hpgl driver in mapgen should work fine with the plotter.
%%%If you want postscript output then look into the Image Alchemy
%%%software (see archives to find more info - this has been brought up
%%%before) for use with mapgen and with the new ps.map.
The mapgen driver for 8 pen plots is hpgl. However, if you are using more
than 8 pens you must use the calhpgl driver. The calhpgl driver is setup for
255 pens.
# # #### #### #### ###### #### ##### Jill R. Schuler
# # # # # # # # # # USDA
# # #### # # #### ### #### # #### Soil Conservation Service
# # # # # # # # # # National Cartography and
# # # # # # # # # # GIS Center
#### #### #### # # #### ###### #### P.O. Box 6567
Ft. Worth, TX 76115
e-mail: jschuler@ncg.scs.ag.gov Phone: (817) 334-5559 x3086
