Hi grass-users & programmers,
in a C application, I set variables (monitor coordinate and dimension, mapset
and location) to new values with G__setenv(), but nothing change!
I try to use G_setenv(), that modifies env file, but I have the same result!!
In the second way the env file has modified, then I try to restart G_gisinit():
NOTHING, NOTHING and NOTHING!!!!!
Could someone help me to change _truely_ the GRASS Environment run-time?
Thanks in advance for your suggestions.
--FRY
