ERDAS .LAN import
I have an ERDAS .LAN (TM image) raster file. I was given the description
for the file format:
128 bytes header
949 rows x 795 cols for the 7 bands (BIL format)
And I tried to write some quick'n'dirty code to extract one band at a time
(for a start). It didn't work.
However, I tend to think that there is something missing to the info I
had, mainly because the size of the .LAN file is bigger than
949x795x7+128. I must be missing some CR/NL here and there (at least).
Is there somebody else who has played around with ERDAS who can give me
more accurate information ?
Thank you.
          Andrea Giacomelli
          andreag@idra1.iar.polimi.it
Andrea Giacomelli (andreag@idra1.iar.polimi.it) writes on 9 May 94:
128 bytes header
I recently imported an ERDAS 7.3 file (created by Multispec, a remote
sensing package for Macintrashes) into GRASS. Here's what I did:
% mkdir $LOCATION/erdas
% mv flc1 $LOCATION/erdas
% dd if=$LOCATION/erdas/flc1 of=$LOCATION/erdas/stripped ibs=128 skip=1
% cd $LOCATION/erdas
% i.tape.other # using $LOCATION/erdas/stripped as input, with no
               # extra skips made.
This worked perfectly. I couldn't get the *in.erdas command(s?) to work
nor could I get i.tape.other to skip over the header (not sure why,
though).
--Darrell
James Darrell McCauley, Purdue Univ, West Lafayette, IN 47907-1146, USA
mccauley@ecn.purdue.edu, mccauley%ecn@purccvm.bitnet, pur-ee!mccauley
** will finish PhD/engr in 9/94 - need job. inquiries welcome (no hh, plz) **
** Personal WWW page URL ftp://pasture.ecn.purdue.edu/pub/mccauley/me.html **
