The ERDAS to GRASS conversion can be relatively straight forward.
If the ERDAS file (either GIS or LAN) is in the 7.3 format (cvt73) and is 8 bit data then use r.in.erdas. I've had much success with this.
If this is not the case then it can be a bit more difficult but not much.
With ERDAS 7.5 the DPDATA command will allow the user to write the output
to a file.
If the Erdas file is a GIS file either BIL or BSQ will work.
For a LAN file use BSQ. The resultant file will have a .blk extension.
Move this file to the GRASS cell directory.
Edit a header file in the cellhd directory to match the output from LISTIT with
the compression set to 0.
for 8bit files the format is 0 for 16bit files the format is 1
The file is now ready for r.support.
The GRASS file will have exactly the same data as the ERDAS file.
_____________________________________________________________________
| Tom Nelson |
| Corps of Engineers |
| Fort Worth, Texas |
| (817) 334-2095 |
|____________________________________________________________________|
