Erdas
Geez, I feel stupid, I figured out that erd2grass is the r.in.erdas command.
I have replaced one problem with another... this is the output from when I
run erd2grass:
OPTION: Name of erdas input file
     key: erdas
required: YES
enter option > kong
You have chosen:
  erdas=kong
Is this correct? (y/n) [y]
OPTION: The files for the n bands will be:
           grasscellfile.1 ....... grasscellfile.n
     key: prefix
required: YES
enter option > kong.1
You have chosen:
  prefix=kong.1
Error can not open ERDAS file
I have the erdas files stored under ./data/acheron/stacey/erdas
with rw-r-r permissions. Where does erd2grass look for the data files?
stacey@gis.wsc.monash.edu.au
r.in.erdas looks in the current directory for the files. You must either be in that directory, or specify the full path name to it.
Jerry Thompson
Spatial Analysis Systems Team
USA-CERL
thompson@zorro.cecer.army.mil
