Error in starting graphics monitor with openwindow version 3
I am getting the following error when I tried to run the grass4.0
under openwindows version 3. Any ideas? I never had problem with openwindow
version 2.
d.mon start=x2
Graph_SetX: display :0.0 doesn't know font 9x15
Please start graphics monitor <x2>.
Srinivasan.
srin@brcsun1.tamu.edu
Make sure you have OPENWINHOME set to the location of openwindows 3 on
your system. The directory $OPENWINHOME/lib/fonts does include the
9x15 font. Otherwise, you can modify .../grass4/src/display/devices/
XDRIVER/XDRIVER/Graph_Set.c to change the FONT to "fixed" (this is a
define near the beginning of the file). Recompile and everything
should be fine. Note that fixed is probably a better choice than 9x15
anyway, since it is guaranteed to exist everywhere.
-kenn
