error in utils/setup
One more comment on the utils/setup routine. It seemed to be failing the
access test when the file searched for is a soft link across NFS. I've had
to give direct pathnames on two occasions now, and I'm anticipating more,
given that our appplications server's disks are crammed.
greg
----- End Included Message -----
From jesse Fri May 28 11:58:59 1993
Sender: lists-owner@moon.cecer.army.mil.
Reply-To: grassp-list@moon.cecer.army.mil.
Precedence: Bulk
To: greg@terra.cor2.epa.gov
Subject: d.3d
Reply-To: jesse@terra.cor2.epa.gov
Date: Fri, 28 May 1993 11:58:55 -0700
X-Lines: 30
Status: O
Content-Length: 1397
Lines: 34
  d.3d, though faster, is now brain dead.
1) The format of 3dview files is different. It no longer retains information
about erase colour, line colour, or average elevations. This must be
changed EACH time a 3dview file is used.
2) It will over-write an existing 3dview file when it uses an old one.
3) It (still) will not allow me to over-write an existing 3dview file when
I exit d.3d. So it can do what it will not allow me to do.
4) It will draw into the full screen frame, even it a sub frame is active.
5) It will do item 4 only AFTER the first time an old 3dview file is used.
Then there is different behaviour between the first use of a 3dview file
from all following uses. This is difficult to reproduce.
  I have not tried it on an lat/long projections yet, so I do not know
if it is still broken in that way.
  Speed is not everything.
R Jesse Chaney Internet: jesse@terra.cor2.epa.gov
Environmental Research Lab Internet: jchaney@research.cs.orst.edu
200 SW 35th Street UUCP: hplabs!hp-pcd!orstcs!jchaney
Oregon State University Phone: (503) 754-4497
Corvallis, Oregon 97333 USA FAX: (503) 754-4338
From daemon Fri Sep 10 09:52:56 1993
Date: Fri, 10 Sep 1993 09:52:55 MDT
Sender: grass-lists-owner@moon.cecer.army.mil.
Precedence: Bulk
To: caa@noaacrd
Subject: printer job
X-Lines: 22
Status: O
Content-Length: 719
Lines: 23
Your printer job (psekform)
could not be printed
Messages from output filter:
%%[ Error: Message: process(0x35fc4c, 'Unnamed process', runnable)
Error: /undefined
Command: V5.1
Ostack: 5.1 -0.9
Estack:
  at: '.array_exec_cont' {/undefined *'standarderroraction'}
  at: '.name_exec' V5.1
  at: '.psparse_token' file(?,W,R) ptr0x0004dc30
  at: '.packedarray_exec_cont' {... 'save' 'put' 'clear' currexecfile 'cvx' *'exec'}
  at: '.stopped_cont'
  at: '.packedarray_exec_cont' {serverdict /save-state 'save' 'put' 'clear' packedarray{17} *'stopped' packedarray{5} 'if' packedarray{3} 'stopped' packedarray{3} ...}
  at: '.end_exec'
Dstack:
  dictionary[49/200]
  package(NeWSprint)
  dictionary[377/2000]
5.1 -0.9
