Error starting graphic monitor
try stopping it first by typing:
  d.mon stop=x0
if that doesn't work, look in the directory:
  $GISBASE/locks/`hostname`/
and remove any old lockfiles which may be there.
also, make sure your DISPLAY environment variable is set correctly - which
it seems to be given your message.
see how you go, this stuff often happens and you've just got to try this sort
of stuff until it fixes itself!
f.
Fred Watson
|PhD student Cooperative Research Centre for Catchment Hydrology|
|fgrw@civag.unimelb.edu.au Department of Civil & Environmental Engineering |
|+61-3-93447237 University of Melbourne |
|+61-3-93446215 (F) Parkville, 3052, Victoria, AUSTRALIA |
