Here is an extract from the code which is causing the error:
ERROR: Too many open raster files
sprintf(chardist,"%i",hold_distance[i]);
strcpy(tempchar,strcat(tempchar,chardist));
sprintf(systemstring,"%s%s%s%s%s%s%s","r.buffer input=",route," output=",r
oute,"_BUFF distances=",tempchar," units=meters");
printf("%s\n",systemstring);
system(systemstring);
system("sleep 3");
sprintf(systemstring,"%s%s%s%s%s%s%s%s%s","r.cross input=\"",map_to_use,",
",route,"_BUFF\", output=",map_to_use,"_",route,"_CR");
if ((fd = G_open_cell_old(map_to_use,mapset)) < 0)
G_fatal_error("Could not open raster map ");
if ((buff_fd = G_open_cell_old(map_buff,mapset)) < 0)
G_fatal_error("Could not open raster buffer map ");
if ((new_map_fd = G_open_cell_new(new_map)) < 0)
G_fatal_error("Could not create overlay map");
for(row = 0; row < nrows;row++)
G_zero_cell_buf(buf);
G_zero_cell_buf(buff_buf);
G_zero_cell_buf(new_map_buf);
G_get_map_row(fd,buf,row);
G_get_map_row(buff_fd,buff_buf,row);
for (col = 0;col < ncols;col++)
tmp = hold_impact[buff_buf[col]] * hold_catrank[buf[col]];
if (tmp == 0)
new_map_buf[col] = MAX_NO_IMPACT/2;
--More-- if (tmp < 0)
new_map_buf[col] = (MAX_NO_IMPACT - (tmp/MAX_NO_IMPACT))/2;
if (tmp > 0)
new_map_buf[col] = ((tmp/MAX_NO_IMPACT) - MAX_NO_IMPACT)/2;
G_put_map_row(new_map_fd,new_map_buf);
G_close_cell(fd);
G_close_cell(buff_fd);
G_close_cell(new_map_fd);
The program is taking a map and a route map, calling r.buuffer and r.cross
by a system call to produce a buffer map and then using
G_open_cell_nap_old and G_open_cell_map_new on 2 and 1 files
respectively to prouduce a new map.As you can see i close all
3 files at the end.
After this, I then run another program ( same executabele), which
draws these four maps : base map, route map, buffer map, my own calculated
map.This is a modification of slide.show.sh as follows:
for i in $MAPLIST
do
atnum=`expr $atnum % $totmaps`
at_vert=`expr $atnum % $DOWN`
at_hori=`expr $atnum / $DOWN`
d.frame -s lab.$at_hori.$at_vert
echo $i in $MAPSET | d.text size=80
d.frame -s map.$at_hori.$at_vert
d.erase
d.rast $i
atnum=`expr $atnum + 1`
done
now, an error occurs on two occasions.Sometimes, the r.buffer command
fails with ERROR: Too many raster files open and sometimes one of the
d.rast commands fails with the same error.When I then exit GRASS and delete
some of my calculated raster files, re-enter and re-run the problem disappears until those files hacve been re-created.
The system I am using is GRASS 4.0 on an RS6000/320 running AIX.
The file descriptor limit seems to be about 2000 -
I ascertained this by running a test C program whcih
fopens files until it falls over,
Any help would be much appreciated.
Joe Mintz, Dept Computer Science, Birkbeck Colleege.
