I've managed to import some vector data OK - drawing the lines everything
seem fine.
Next I wanted to add the labels to them - to do this I have created a
file with each line in the format "L 999999 999999 cat" as discussed in
the programmers guide. Place that file (with the same name as the vector)
in the 'dig_att' directory and then run 'v.support' - I then get a number
of lines of the form 'WARNING: line xx label ... matched another label
....' - thing is I've looked at the two lines and can't see how they
match - the
coordinates look different and the label is just a unique identifier
Can anyone cast any light on what is going on.
Steve Culshaw
NRA North West
e-mail : nra@cix.compulink.co.uk (use this for general usage)
or sculshaw@cix.compulink.co.uk (Private - only checked at best
biweekly)
