We have our GEOSERVER (with CAS auth)docker image running in kubernetes deployment.
In the logs I could see below error all the time and also our Main App (Shows geoserver layers in UI) users complains they’re being logged out of geoserver while using their applications and do not see any layers.
20 dec. 16:16:50 DEBUG [geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:97)
at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:69)
at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:229)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:57)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:346)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:221)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:178)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:153)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:100)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:54)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:168)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:481)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
since you’re running on k8s, may it be that you’re running more than one pod with a load balancer in front? If so you’ll have to configure it to use sticky sessions. GeoServer won’t share the session across instances.
Hi Groldan, Thanks for your information. Yes I’m running multiple pods. Do we have any documentation or sample configurations about sticky sessions on Geoserver Instance?
I do have enabled Sticky session with below configs,
Ingress: all: path: / feature: - sticky annotations: nginx.ingress.kubernetes.io/affinity: cookie nginx.ingress.kubernetes.io/proxy-body-size: 100M nginx.ingress.kubernetes.io/session-cookie-samesite: None nginx.ingress.kubernetes.io/proxy-read-timeout: 12000 nginx.ingress.kubernetes.io/session-cookie-expires: "180000" nginx.ingress.kubernetes.io/session-cookie-max-age: "180000" nginx.ingress.kubernetes.io/affinity-mode: persistent
