execute GRASS commands outside of GRASS?
Is it possible to run GRASS commands from a non-GRASS program or from the
system prompt? If so, what extra details do I need to track?
I have looked at some of the shell scripts in the src/scripts directory but
they expect to be called while GRASS is running (from the GRASS prompt).
I wanted to this a while back and got the following script working. I then
decided that I didn't really want to do it at all so I havn't much experience
to tell you about ... I doubt that all the setenv's are actually needed.
--------------- cut here ---------------
#!/usr/local/bin/tcsh
set path= (/user/grass4.1beta/sun4/bin /user/grass4.1beta/sun4/scripts /user/grass4.1beta/sun4/garden/bin /user/grass4.1beta/sun4/alpha/bin /usr/local/bin /usr/bin /usr/ucb /etc /usr/etc /usr/lib)
setenv GISBASE /user/grass4.1beta
setenv GISDBASE /home/grass
setenv GISRC dss_grassrc
setenv LOCATION /home/grass/tyne/phil
setenv LOCATION_NAME tyne
setenv MAPSET phil
g.list rast
Phil Watson (an ozzie in exile) | _--_|\ | CLUWRR |
phil.watson@newcastle.ac.uk | / \ | Agric & Enviromental Science |
                                  | \_.--._/ | Uni of Newcastle-Upon-Tyne |
Phone: (091) 222 7503 | v | England, NE1 |
