Exporting SGI graphics?
Also, once you convert rgb images to ppm, you can use pnm-plus tools or
xv, a public domain image viewer/enhancer.
One thing that all should be aware of is that xv is an 8 bit tool. Even
if you read in a 24 bit image (which is commonly generated on an SGI), xv
will convert it to 8 bits-colormapped. When it is saved, you will have
an 8 bit file, not a 24 bit file.
      o o o o o o o . . . ________________________________ _____=======_T___
    o _____ ||Wes Barris | | wes@msc.edu |
  .][__n_n_|DD[ ====|____ |Research Equipment Inc. dba | |(612) 626-8090 |
>(________|__|_[___/_____]_|Minnesota_Supercomputer_Center|_|_FAX: 626-1596_|_
_/oo OOOOOO o` ooo ooo 'o^o^o o^o^o` 'o^o o^o`
A programming language is low-level when its programs require attention to the irrelevant.
