Extracion from 8 mm tapes
Would you detail how you did it so others that run into this can
repeat what you did?
|I found out I can use m.examine.tape to get the rows and columns and then
|use i.tape.other to extract the TM data from 8mm tapes. Thanks for all
|the input, however.
|Pam (Thompson) Sydelko
Michael
