Extracting smaller raster images from big ones
Help! I don't know if this is an obvious question, but I have been
searching the Grass manual and can't find an answer - I have large raster
images and want to extract smaller ones from them for the purpose of
supervised classification. How do I do this? I have the coords of the
smaller images I want. Defining smaller regions doesn't help, since
i.class doesn't take a region name, it simply loads the entire image !
Please help.... I don't want to export to IDRISI, then extract, and then
reimport, as that would take rtoo much time.
Thanks a lot
Harini
| Harini Nagendra E-MAIL : harini@ces.iisc.ernet.in |
| Center for Ecological PHONE : 91 80 309 2639 (Hostel: LR-94)|
| Sciences : 91 80 309 2506 (Department) |
| Indian Institute of Science FAX : 91 80 334 1683 |
| Bangalore 560 012 India TELEX : 845 8349 IISc IN |
The trick is to save the zoomed image as a new raster file. So, first specify
your new region, then use r.resample to obtain a new image. Good luck!
Philip Verhagen
                     philip@raap2.ivambv.uva.nl
                              R A A P
                        Plantage Muidergracht 14
                          1018 TV Amsterdam
                           The Netherlands
                        tel: +31 (20) 421 62 00
                        fax: +31 (20) 421 42 90
                http://raap2.ivambv.uva.nl/home_eng.html
